[Proj] Converting to SRS:4326
Ed McNierney ed at topozone.com
Tue Jul 17 20:04:16 PDT 2007
Bradley -
If you are going to provide extents to MapServer for latitude and
longitude values in degrees, you need to provide decimal numbers, not
degrees, minutes, and seconds.
-          Ed
Ed McNierney
TopoZone.com
[mailto:proj-bounces at lists.maptools.org] On Behalf Of Bradley Mclain
Sent: Tuesday, July 17, 2007 10:41 PM
To: PROJ.4 and general Projections Discussions
Subject: Re: [Proj] Converting to SRS:4326
Yes sorry to mention thats what I was doing and I got the same results
as you did but these do not work in mapserver as it says that the extent
is invalid. I'm pretty sure it has to do with the d's etc.
On 7/18/07, Frank Warmerdam <warmerdam at pobox.com> wrote:
Bradley Mclain wrote:
> I am having some slight problems with what you are saying, firstly If
I use
> proj -I +init=epsg:28355
> I get a long list of different projections but no new numbers or
anything.
Bradley,
I don't know this is.  When I use that commandline I get the usual
wait-for-input state, and no output till I enter values.
> Also secondly I am not exactly sure what input values I have to put
it.
> Is it my current extent or is it the longitude latitude values which
> match this?
> What I want to get out is the correct extent for my map in EPSG:4326.
> Its current extent using EPSG:28355 is 301964.225304 6172911.602455
> 439497.461276 6230476.242273
> With latitude and longitude 146.123 -34.2918 146.152 -34.2685
The proj command reprojects points, not rectangles.  You can get
a rough idea by reprojecting two corners, or a better representation
by reprojecting all four corners.  For instance if I do the following
warmerda at amd64[49]% proj -I +init=epsg:28355 << EOF
? 301964.225304 6172911.602455
? 439497.461276 6230476.242273
? EOF
I get:
144d50'28.65"E  34d33'59.396"S
146d20'39.655"E 34d3'52.921"S
Best regards,
I set the clouds in motion - turn up   | Frank Warmerdam,
and watch the world go round - Rush    | President OSGeo,
http://osgeo.org
Proj mailing list
Proj at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20070717/023a74d0/attachment.html>
