[Proj] Converting to SRS:4326
Bradley Mclain
bradleym06 at gmail.com
Tue Jul 17 19:41:00 PDT 2007
Yes sorry to mention thats what I was doing and I got the same results as
you did but these do not work in mapserver as it says that the extent is
invalid. I'm pretty sure it has to do with the d's etc.
On 7/18/07, Frank Warmerdam <warmerdam at pobox.com> wrote:
> Bradley Mclain wrote:
> > I am having some slight problems with what you are saying, firstly If I
> use
> > proj -I +init=epsg:28355
> > I get a long list of different projections but no new numbers or
> anything.
> Bradley,
> I don't know this is. When I use that commandline I get the usual
> wait-for-input state, and no output till I enter values.
> > Also secondly I am not exactly sure what input values I have to put it.
> > Is it my current extent or is it the longitude latitude values which
> > match this?
> > What I want to get out is the correct extent for my map in EPSG:4326.
> > Its current extent using EPSG:28355 is 301964.225304 6172911.602455
> > 439497.461276 6230476.242273
> > With latitude and longitude 146.123 -34.2918 146.152 -34.2685
> The proj command reprojects points, not rectangles. You can get
> a rough idea by reprojecting two corners, or a better representation
> by reprojecting all four corners. For instance if I do the following
> warmerda at amd64[49]% proj -I +init=epsg:28355 << EOF
> ? 301964.225304 6172911.602455
> ? 439497.461276 6230476.242273
> ? EOF
> I get:
> 144d50'28.65"E 34d33'59.396"S
> 146d20'39.655"E 34d3'52.921"S
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | President OSGeo, http://osgeo.org
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20070718/89592b62/attachment.html>
More information about the Proj
