[Proj] Re: another approach
Sergey Spiridonov
sena at hurd.homeunix.org
Thu Mar 1 04:52:09 PST 2007
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Another approach I can think of is having set of key points (let's say
5-20) on the Earth (lat,lon), which will be projected in both
projections which are compared. Than the resulting map coordinates can
be compared. If projections are the same, map coordinates of the
projected points will be also the same. If projections differ, thanwell,
map coordinates should be also different? (if set is good enough?)
What do you think about this?
Best regards, Sergey Spiridonov
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.6 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iD8DBQFF5sx5J3NEeIx4r3YRAkdAAJ4wgCt3dupGGLpmggwfNjxXcIT2UACfXM1F
noX6tHdY3DZtKt5A19FPtCw=
=OJnt
-----END PGP SIGNATURE-----
More information about the Proj
