[Proj] Re: how to compare 2 proj4 definitions? or: how to normalize proj4 definition?
Sergey Spiridonov sena at hurd.homeunix.org
Fri Mar 9 01:37:42 PST 2007
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
I found workaround for my application so I will not work on this problem
soon.
For somebody who would like to implement it, I will recommend the
following way:
Compare +proj=<def> option and, if they are equal, project several
points (each projection type can have its own subset) and compare
results using predefined (but user-configurable) exactness.
In case there will be need to improve comparision speed, projection
signature can be created. Projection signature should include projection
type and projected coordinates (already rounded to the certain exactness).
Best regards, Sergey Spiridonov
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.6 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iD8DBQFF8SrmJ3NEeIx4r3YRAn/ZAJwN7Jgv56O+t5QIXaNapFtcfcrz8gCZAaNR
SrbF2rNr3BDphLNxDMOOvWk=
=eZaX
-----END PGP SIGNATURE-----
