[Proj] cs2cs additional fields beyond coords passed thru
Thu Apr 24 09:51:49 PDT 2008
Mark Wimer wrote:
> Hi all,
> I am new to using cs2cs, and the documentation says that info to the
> right of the coordinates get sent to output. It specifies this is true
> for ASCII files.
Mark,
It turns out it was pretty easy to fix cs2cs to support passthrough
(with caveats about the Z value).  I have attached the updated cs2cs
code in case you would like to use it.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
Type: text/x-csrc
Desc: not available
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20080424/a6fb1a85/attachment.c>
