[Proj] cs2cs additional fields beyond coords passed thru
Mark Wimer
mwimer at usgs.gov
Thu Apr 24 10:36:14 PDT 2008
Thanks Frank for the response and assistance ! Hope it's helpful to others
as well.
thanks again,
Mark
Mark Wimer wrote:
> Hi all,
> I am new to using cs2cs, and the documentation says that info to the
> right of the coordinates get sent to output. It specifies this is true
> for ASCII files.
Mark,
It turns out it was pretty easy to fix cs2cs to support passthrough
(with caveats about the Z value). I have attached the updated cs2cs
code in case you would like to use it.
Best regards,
I set the clouds in motion - turn up | Frank Warmerdam,
warmerdam at pobox.com
and watch the world go round - Rush | President OSGeo, http://osgeo.org
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20080424/8ed0a77f/attachment.html>
More information about the Proj
