[Proj] proj-4.6.0 and BETA2007.gsb
Oliver Eichler oliver.eichler at dspsolutions.de
Wed Jan 23 08:49:18 PST 2008
Hi Frank,
looks like this mail died in the mail filter because it was to big. Thus
once again without the BETA2007 file:
> Presumably the +datum=potsdam is embedded in "strProj" from the
> exportToProj4()
> result.  The issue is that exportToProj4() produces default information
> for the Potsdam datum which you want to override with the BETA2007.gsb
> grid file.  To do so you have to add the +nadgrids, and strip
> +datum=potsdam
> out of the string returned by exportToProj4.
No, it's not that simple.  I have attached a small C file.  I compile it
with:
gcc testpro.c -L/usr/lib64 -lproj -otestpro
On the machine with the Proj4-4.6 version this will output (bad):
4487992.480929,5421613.273181
On the machine with the Proj4-4.5 version this will output (good):
4488097.842111,5421724.742397
The BETA2007 file you get here.
http://crs.bkg.bund.de/crseu/crs/descrtrans/BeTA/de_dhdn2etrs_beta.php
Thanks for help
Oliver
Type: text/x-csrc
Desc: not available
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20080123/8c0456f0/attachment.c>
