[Proj] proj-4.6.0 and BETA2007.gsb
Frank Warmerdam
warmerdam at pobox.com
Wed Jan 23 10:57:10 PST 2008
Oliver Eichler wrote:
> No, it's not that simple. I have attached a small C file. I compile it
> with:
> gcc testpro.c -L/usr/lib64 -lproj -otestpro
> On the machine with the Proj4-4.6 version this will output (bad):
> 4487992.480929,5421613.273181
> On the machine with the Proj4-4.5 version this will output (good):
> 4488097.842111,5421724.742397
/lists.maptools.org/mailman/listinfo/proj
Oliver,
You are quite right. I tried this out and determined that you need
to declare your WGS84 coordinate system as +datum=WGS84, not +ellps=WGS84.
The big change in PROJ 4.6.0 was that pj_transform() will no longer try to
apply datum shifts if either the source or destination lack a datum
declaration (either +datum, +towgs84 or +nadgrids). Your WGS84 declaration
was "+proj=longlat +ellps=WGS84 +no_defs" which means a geographic
coordinate system on the WGS84 ellipsoid but it provides no datum shift
info to get to the WGS84 datum.
Sorry for not realizing this sooner.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
More information about the Proj
