[Proj] Re: Linear projections reply
Michael Ossipoff mikeo2106 at msn.com
Tue Jul 1 10:32:15 PDT 2008
(Line-format faults prevent me from using the ">" marks)
Dan Strebe:
You'd said:
Cylindric projections are a specialization of pseudocylindric.  Whether it is incorrect to call a cylindric projection  "pseudocylindric" is something best left to  those of uselessly  pedantic temperment.
I'd replied:
 Oh come on now, you're saying that no one should ever say anything about the merits of a term.
You replied:
I fail to see how my comment could be interpreted anywhere nearly so generally.
I reply:
Well, specifically, if ever there was a map projection term that needed a new name, it's "pseudocylindrical", when interpreted to encompass "cylindrical".
If there's some specific reason why it would be uselessly pedantic to suggest a better word for that particular term, you failed to tell it. We're talking about a prefix used in a way contrary to its otherwise universally-accepted meaning, making a self-contradictory usage.
You said:
This does not seem to be going anywhere. Good luck.
I reply:
Well, it was a nonstarter when you posted your unexplained remark quoted at the beginning of this post. Good luck with what? You made a statement and I answered it. It isn't clear why you expected it to go somewhere after that.
Mike Ossipoff
