[Proj] Long. Lat conversion to Cartesian coordinates
Jose Gonçalves jagoncal at gmail.com
Wed Jul 2 16:01:59 PDT 2008
Use character > to redirect standard output (by default, the screen) to a
file:
proj +proj=poly asd.txt > out_file.txt
Regards
Jose'
2008/7/2 Mohamed Mohamed <enxmabm at nottingham.ac.uk>:
> Hi,
> I have a file named asd.txt. This file contain longitudinal latitudinal
> coordinates points. When I use proj +proj=poly asd.txt command. I got
> the answer in the command line. However I want the answer to be sorted
> in  a new file.
> Can any one help?
> M.A.Bek
> SChEME Department
> Faculty of Engineering
> University of Nottingham
> Nottingham (NG7 2RD) UK
> Fax: 0044(0)115 951 4115
> This message has been checked for viruses but the contents of an attachment
> may still contain software viruses, which could damage your computer
> system:
> you are advised to perform your own checks. Email communications with the
> University of Nottingham may be monitored as permitted by UK legislation.
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20080703/e495b3b5/attachment.html>
