[Proj] Long. Lat conversion to Cartesian coordinates
support.mn at elisanet.fi
Wed Jul 2 18:58:29 PDT 2008
Hello,
as somebody said, you should redirect the output to a text file using
the "> out_file.txt" at the end of the command line in WIndows
command console.
If you also need to sort that file based on some column, you can use
such a program as "EditPlus 3", which is an editor and it has a tool
that does the sorting. See:
http://www.editplus.com/
Regards: Janne
> Hi,
> I have a file named asd.txt. This file contain longitudinal latitudinal
> coordinates points. When I use proj +proj=poly asd.txt command. I got
> the answer in the command line. However I want the answer to be sorted
> in a new file.
> Can any one help?
> M.A.Bek
> SChEME Department
> Faculty of Engineering
> University of Nottingham
> Nottingham (NG7 2RD) UK
> Fax: 0044(0)115 951 4115
> This message has been checked for viruses but the contents of an attachment
> may still contain software viruses, which could damage your computer system:
> you are advised to perform your own checks. Email communications with the
> University of Nottingham may be monitored as permitted by UK legislation.
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
More information about the Proj
