[Proj] Installing Proj on a Mac
Christopher Barker Chris.Barker at noaa.gov
Mon Jul 7 11:38:19 PDT 2008
William Kyngesburye wrote:
>  I have a complete set of
> binaries for PROJ, GEOS, GDAL and a few others in OSX "framework" form.
I highly recommend these.
William, would you consider having your Frameworks put links in to the
executables in /usr/local/bin ? That might be handy. Or maybe link them
all to one location in /Library/Frameworks, and then put that in the PATH.
For instance, I have:
# Setting PATH for GDAL Current
PATH="/Library/Frameworks/GDAL.framework/Versions/Current/Programs:${PATH}"
# Setting PATH for MapServer Current
PATH="/Library/Frameworks/MapServer.framework/Versions/Current/Programs:${PATH}"
in my .profile, but it's getting a bit tedious to keep adding each one.
That's one thing I've always liked about *nix -- there are standard
places to put stuff, so I don't need to add a bazillion things to my
PATH, like I did in the DOS days. And symlinks let you have the best of
both worlds!
-Chris
Christopher Barker, Ph.D.
Oceanographer
Emergency Response Division
NOAA/NOS/OR&R            (206) 526-6959   voice
7600 Sand Point Way NE   (206) 526-6329   fax
Seattle, WA  98115       (206) 526-6317   main reception
