[Proj] PROJ 4.6.1 RC1
Gerald I. Evenden geraldi.evenden at gmail.com
Tue Jul 22 13:08:59 PDT 2008
On Monday 21 July 2008 9:41:08 pm Frank Warmerdam wrote:
> Folks,
> I have prepared a release candidate for a 4.6.1 release.
>    http://download.osgeo.org/proj/proj-4.6.1RC1.tar.gz
> 4.6.1 Release Notes
>   o Upgraded to EPSG 6.17 version for nad/epsg.  Also corrected the
> precision problem introduced in the last version.
>   o Added logic for tmerc projection to fail rather than return crazy
> results if more than 90 degrees away from the central meridian (#5).  This
> change may only be temporary till a more comprehensive solution is found.
I strongly suggest that if you insist upon limits, put them at about 45
degrees (even that is absurd).  Most tmercs will fail around +-90 and are
unreliable at ~+-80.
Of course, tmerc itself is only functional up to about +-5.
>   o Fixed handling of extra text in cs2cs.
>   o Renamed INSTALL to INSTALL.TXT.
>   o The eqc projection has been generalized to include a latitude of
> origin.
>   o Added the glabsgm (Gauss Laborde / Sphere Geometric Mean) projection
>   o nad/IGNF init catalogue created.
>   o added the ntf_r93.gsb datum shift file.
> I'd appreciate some feedback before declaring this an official release.
> Best regards,
The whole religious complexion of the modern world is due
to the absence from Jerusalem of a lunatic asylum.
-- Havelock Ellis (1859-1939) British psychologist
