[Proj] PROJ 4.6.1 RC1
Gerald I. Evenden
geraldi.evenden at gmail.com
Tue Jul 22 13:19:37 PDT 2008
On Monday 21 July 2008 9:41:08 pm Frank Warmerdam wrote:
> Folks,
> I have prepared a release candidate for a 4.6.1 release.
> http://download.osgeo.org/proj/proj-4.6.1RC1.tar.gz
> 4.6.1 Release Notes
> o Upgraded to EPSG 6.17 version for nad/epsg. Also corrected the
> precision problem introduced in the last version.
> o Added logic for tmerc projection to fail rather than return crazy
> results if more than 90 degrees away from the central meridian (#5). This
> change may only be temporary till a more comprehensive solution is found.
> o Fixed handling of extra text in cs2cs.
> o Renamed INSTALL to INSTALL.TXT.
> o The eqc projection has been generalized to include a latitude of
> origin.
> o Added the glabsgm (Gauss Laborde / Sphere Geometric Mean) projection
This is called "glaborde" in libproj4. I don't know where "Sphere Geometric
Mean" comes from.
> o nad/IGNF init catalogue created.
> o added the ntf_r93.gsb datum shift file.
> I'd appreciate some feedback before declaring this an official release.
> Best regards,
The whole religious complexion of the modern world is due
to the absence from Jerusalem of a lunatic asylum.
-- Havelock Ellis (1859-1939) British psychologist
More information about the Proj
