[Proj] FWTools and Proj: Installation
Frank Warmerdam
warmerdam at pobox.com
Thu Jun 5 11:41:12 PDT 2008
Conor O'Donoghue wrote:
> I am new to FWTools and Proj
> I installed the windows version of FWTools 2.0.6 but it does not appear
> to be working.
> Can someone tell me what command to use in order to check correct
> installation.
> Thanks
> Conor
> PS: Is there such a thing as a beginner, non-programmer tutorial or
> equivalent?
Conor,
Generally speaking you are best off reviewing the user docs for the
component packages to learn more about using FWTools. How did you
determine it is not working? You mentioned PROJ in the subject line.
It would normally be used by opening the FWTools shell and then
issuing a command like:
cs2cs +proj=utm +zone=11 +datum=WGS84 +to +proj=latlong +datum=WGS84
and then entering x/y coordinates like:
250000 1300000
and you should get back a long/lat location like:
119d17'38.017"W 11d45'2.313"N 0.000
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
More information about the Proj
