[Proj] FWTools and Proj: Installation
Hamish hamish_b at yahoo.com
Thu Jun 5 17:32:44 PDT 2008
Conor O'Donoghue wrote:
> I am new to FWTools and Proj
> I installed the windows version of FWTools 2.0.6 but it
> does not appear to be working.
> Can someone tell me what command to use in order to check
> correct installation.
look in the FWTools dir, there is a .bat file there called setup fw vars or something like that. In the terminal run that before trying to use the tools. Or edit whatever autoexec.bat is these days to have that happen each time you start up.
Hamish
Hamish
