[Proj] FWTools and Proj: Installation
Conor O'Donoghue
theconor at yahoo.com
Thu Jun 5 22:51:42 PDT 2008
Hamish and Frank,
I have another question.... but first, thanks for the input. By following both instructions i did get the correct result.
I only need FWTools to convert from one projection to another from the command line, usually starting with a GeoTiff in Geographic projection.
Could you give me one example (so I can see the syntax) using source.tif (geographic projection GeoTIFF) for input and creating an output GeoTIFF named destination.tif in Mercator projection.
Thanks again
Conor
----- Original Message ----
To: proj at lists.maptools.org
Sent: Thursday, June 5, 2008 5:32:44 PM
Subject: Re: [Proj] FWTools and Proj: Installation
Conor O'Donoghue wrote:
> I am new to FWTools and Proj
> I installed the windows version of FWTools 2.0.6 but it
> does not appear to be working.
> Can someone tell me what command to use in order to check
> correct installation.
look in the FWTools dir, there is a .bat file there called setup fw vars or something like that. In the terminal run that before trying to use the tools. Or edit whatever autoexec.bat is these days to have that happen each time you start up.
Hamish
Hamish
Proj mailing list
Proj at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20080605/d715db3d/attachment.html>
More information about the Proj
