[Proj] FWTools and Proj: Installation
Thu Jun 5 23:08:09 PDT 2008
Conor O'Donoghue wrote:
> Hamish and Frank,
> I have another question.... but first, thanks for the input. By
> following both instructions i did get the correct result.
> I only need FWTools to convert from one projection to another from the
> command line, usually starting with a GeoTiff in Geographic projection.
> Could you give me one example (so I can see the syntax) using
> source.tif (geographic projection GeoTIFF) for input and creating an
> output GeoTIFF named destination.tif in Mercator projection.
Conor,
Perhaps something like:
   gdalwarp -t_srs '+proj=merc +datum=WGS84' source.tif destination.tif
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
