[Proj] from EPSG:28992 to EPSG:25832
Roger Oberholtzer
roger at opq.se
Thu Mar 20 12:33:41 PDT 2008
On Thu, 2008-03-20 at 16:29 +0100, Bart van den Eijnden (OSGIS) wrote:
> Hi list,
> why is the conversion from EPSG:28992 to EPSG:25832 not very accurate?
> The official calculator from agrs.nl gives the following:
> Original system RD and NAP
> X 196197,31
> Y 390964,35
> Target system UTM(ETRS89)
> Zone 32
> Northing 5710439,825
> Easting 290464,836
> This is what I get with PROJ 4.6:
> cs2cs -f %.9f +proj=sterea +lat_0=52.15616055555555 +lon_0=5.38763888888889
> +k=0.999908 +x_0=155000 +y_0=463000 +ellps=bessel +units=m
> +towgs84=565.2369,50.0087,465.658,-0.406857330322398,0.350732676542563,-1.8703473836068,4.0812
I have this for converting to RD (I am converting from WGS84):
+towgs84=565.040,49.910,465.840,-0.40939,0.35971,-1.86849,4.0772
and my users are happy with the results. Not sure if this applies for
you. But it is all I can offer.
> +no_defs +to +proj=utm +zone=32 +ellps=GRS80 +units=m +no_defs
> 196197.31 390964.35
> 290505.483235725 5710539.888875010 0.000000000
> Any ideas what could be causing this? Is there a correction grid involved (I
> am no projections expert unfortunately ... ).
> TIA.
> Best regards,
> Bart
> OSGIS, Open Source GIS
> http://www.osgis.nl
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
Roger Oberholtzer
OPQ Systems / Ramböll RST
Ramböll Sverige AB
Kapellgränd 7
P.O. Box 4205
SE-102 65 Stockholm, Sweden
Tel: Int +46 8-615 60 20
Fax: Int +46 8-31 42 23
More information about the Proj
