[Proj] from EPSG:28992 to EPSG:25832
Bart van den Eijnden (OSGIS)
bartvde at osgis.nl
Fri Mar 28 10:22:20 PDT 2008
An update on this issue after I had some contact with Jan Hartmann.
There is something strange going on in our opinion, the same command
yields different results in PROJ 4.5 and 4.6. PROJ 4.5 is very close to
the expected result.
PROJ 4.6:
cs2cs -f %.9f +proj=sterea +lat_0=52.15616055555555
+lon_0=5.38763888888889 +k=0.999908 +x_0=155000 +y_0=463000
+ellps=bessel +units=m
+towgs84=565.2369,50.0087,465.658,-0.406857330322398,0.350732676542563,-1.8703473836068,4.0812
+no_defs +to +proj=utm +zone=32 +ellps=GRS80 +units=m +no_defs
96197.31 390964.35
290505.483235725 5710539.888875010 0.000000000
PROJ 4.5:
290464.957702205 5710439.900326397 44.377755052
If Jan changes the ellipsoid of the UTM zone from GRS80 to WGS84 things
are okay in PROJ 4.6.
Can somebody shed some light on this? Did something changes with the
ellipsoids? How can different PROJ versions yield different results on
the same command?
Best regards,
Bart
Bart van den Eijnden (OSGIS) wrote:
> Hi list,
> why is the conversion from EPSG:28992 to EPSG:25832 not very accurate?
> The official calculator from agrs.nl gives the following:
> Original system RD and NAP
> X 196197,31
> Y 390964,35
> Target system UTM(ETRS89)
> Zone 32
> Northing 5710439,825
> Easting 290464,836
> This is what I get with PROJ 4.6:
> cs2cs -f %.9f +proj=sterea +lat_0=52.15616055555555 +lon_0=5.38763888888889
> +k=0.999908 +x_0=155000 +y_0=463000 +ellps=bessel +units=m
> 196197.31 390964.35
> Any ideas what could be causing this? Is there a correction grid involved (I
> am no projections expert unfortunately ... ).
> TIA.
> Best regards,
> Bart
> OSGIS, Open Source GIS
> http://www.osgis.nl
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
bartvde at osgis.nl
http://www.osgis.nl
More information about the Proj
