[Proj] Datum shift for Dutch maps 1850-2000
support.mn at elisanet.fi
Wed Nov 26 03:22:49 PST 2008
Hello,
north shifts can also be generated from transition between spherical
and elliptical earth... or between different ellipsoids. If it used it's
own ellipsoid (or sphere), I am rather sure that the shift comes from
there. Try an other ellipsoid or maybe even some sphere.. that might
explain the difference?
Regards: Janne.
Jan Hartmann [j.l.h.hartmann at uva.nl] kirjoitti:
> This is not a question about the program PROJ, but perhaps there are
> people on this list that can help me. I am georeferencing the first
> topographical map of the Netherlands from about 1850. That map is in a
> Bonne projection centered at 51.5N / 4.8838828E, and uses its own
> ellipsoid, computed by the Dutch engineer Ackermans (semi-major axis
> 6376950.4m, inverse flattening 309.65m). Its PROJ-string is:
> +proj=bonne +lat_1=51.5 +lon_0=4.8838828 +a=6376950.4 +rf=309.65
> +units=m +no_defs
> The present Dutch topograpical maps use a stereographic projection on
> the Bessel ellipsoid, defined (without the WGS84 datum shift) as:
> +proj=sterea +lat_0=52.15616055555555 +lon_0=5.38763888888889
> +k=0.999908 +x_0=155000 +y_0=463000 +ellps=bessel +units=m +no_defs
> We have the complete lists of triangulation points used for both maps,
> 1000 in 1850 and 5000 in 2006. Quite a few points are identical,
> mostly church towers, so for these we have coordinates in both
> projections. The lists also contain the lat-lon values for these
> points. When I use cs2cs to reproject the old points into the
> present system, I get a difference of about 650 meter, almost
> exclusively in the Y-direction: the reprojected 1850 map lies about 650
> meter to the north of the present map. This different is exactly the
> same over the whole country, give or take a few meters that look random
> to me (could be measurement errors, plus I am not sure they used the
> same spot on the church towers in 1850 and the present).
> This means I can get a reasonably accurate historical map by just doing
> a linear shift of -10/-650 meters, but I am curious what happens here.
> Of course the center of projection in 1850 could be actually 650m away
> from its recorded position, but I am wondering if there are other
> possibilities for such a shift. Am I doing something slightly wrong? Any
> help would be appreciated.
> Jan
> Dr. J. Hartmann
> Department of Geography
> University of Amsterdam
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
More information about the Proj
