[Proj] Michigan georef projection reproject to lat-lon
Chris Fahner chris at mi-sledding.com
Wed Sep 3 14:05:04 PDT 2008
Tried to send the zip file last night just noticed that it is awaiting
approval from the moderator as it was over 40kb. I put that on my site. If
you want to look at what I received from Michigan DNR.
E-mail from last night.
To my knowledge this is the coordinate system for the file.
Hotine_Oblique_Mercator_Azimuth_Natural_Origin
When I run orginfo.exe on the file I returns Using driver 'ESRI Shapefile'
successful.
1: snow_trails_version1 <Line String>
File is located at. http://www.mi-sledding.com/snow_trails_version1.zip
Chris
-----Original Message-----
From: proj-bounces at lists.maptools.org [mailto:proj-bounces at lists.maptool
s.org] On Behalf Of Richard Greenwood
Sent: Wednesday, September 03, 2008 7:41 AM
To: PROJ.4 and general Projections Discussions
Subject: Re: [Proj] Michigan georef projection reproject to lat-lon
Looks like your source EPSG code might be 3078
Rich
On Tue, Sep 2, 2008 at 6:41 PM, Chris Fahner <chris at mi-sledding.com> wrote:
> When I tried to run the string I entered I received an error.
> Ogr2ogr.exe D:\proj D:\snow_trails_version1.shp -s_srs EPSG: 99999 -t_srs
> EPSG: 4326
> The error is:
> ERROR 4: Unable to open EPSG Support file gcs.csv
> Try setting GDAL_DATA environment variable to point to the
> Directory containing EPSG csv files.
> Failed to process SRS definition: EPSG:
> I am using 99999 because I had to copy the data from the .prj file that
was
> zipped with the shp file as it wasn't available in the epsg file.
> This is what was in the .prj file
PROJCS["NAD_1983_Hotine_Oblique_Mercator_Azimuth_Natural_Origin",GEOGCS["GCS
_North_American_1983",DATUM["D_North_American_1983",SPHEROID["GRS_1980",6378
137.0,298.257222101]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.01745329251994
33]],PROJECTION["Hotine_Oblique_Mercator_Azimuth_Natural_Origin"],PARAMETER[
"False_Easting",2546731.496],PARAMETER["False_Northing",-4354009.816],PARAME
TER["Scale_Factor",0.9996],PARAMETER["Azimuth",337.25556],PARAMETER["Longitu
de_Of_Center",-86.0],PARAMETER["Latitude_Of_Center",45.30916666666667],UNIT[
> "Meter",1.0]]
> [mailto:proj-bounces at lists.maptools.org] On Behalf Of Richard Greenwood
> Sent: Monday, September 01, 2008 8:11 PM
> FWTools http://fwtools.maptools.org/ (which includes Proj.4) has a
> command line program called ogr2ogr which includes coordinate system
> transformation. At the command prompt, you would enter something like:
>   ogr2ogr destDir srcFile.shp -s_srs EPSG:codeForMichiganDNR -t_srs
> EPSG:codeForLatLong
> where:
>  destDir is an empty destination (output) directory
>  srcFile.shp is the name of the snowmobile shapefile
>  codeForMichiganDNR is the EPSG number for your source data (maybe
> not required)
>  codeForLatLong is the EPSG number for lat-long (probably 4326)
> Rich
> On Mon, Sep 1, 2008 at 5:30 PM, Chris Fahner <chris at mi-sledding.com>
wrote:
>> Hello,
>> I have been trying for the longest time now to convert data I received
> from
>> Michigan DNR to lat-long data so it can be used within Google maps.
>> The data is snowmobile trails but I can't for the life of me find a
> program
>> which does not contain an large price tag to do this for me. I can't see
>> spending money on it when I just need to convert the data once and then I
>> won't need it done anymore. Does anyone have a good program to use to do
>> this. They included all the files with the zip file they sent me. (.dbf,
>> .prj, .sbn,.sbx,.shp,.shp.xml,shx). I think I've tried to use more than a
>> handful of software's. The closest I got was with the program map window
> but
>> there seems to be an issue with it reprojecting.
>> Thanks,
>> Chris
>> Proj mailing list
>> Proj at lists.maptools.org
>> http://lists.maptools.org/mailman/listinfo/proj
> Richard Greenwood
> richard.greenwood at gmail.com
> www.greenwoodmap.com
> Proj mailing list
> Proj mailing list
Richard Greenwood
Proj mailing list
