[Proj] Michigan georef projection reproject to lat-lon
Chris Fahner
chris at mi-sledding.com
Wed Sep 3 16:51:36 PDT 2008
When I tried
Ogr2ogr.exe D:\proj D:\snow_trails_version1.shp -s_srs EPSG: 3078 -t_srs
EPSG: 4326
And
They both returned the same error code that I had last night
> ERROR 4: Unable to open EPSG Support file gcs.csv
> Try setting GDAL_DATA environment variable to point to the
> Directory containing EPSG csv files.
> Failed to process SRS definition: EPSG:
Chris
-----Original Message-----
[mailto:proj-bounces at lists.maptools.org] On Behalf Of Richard Greenwood
Sent: Wednesday, September 03, 2008 7:41 AM
To: PROJ.4 and general Projections Discussions
Subject: Re: [Proj] Michigan georef projection reproject to lat-lon
Looks like your source EPSG code might be 3078
Rich
More information about the Proj
