[Proj] UTM map calibration in several zones?!?
support.mn at elisanet.fi support.mn at elisanet.fi
Sat Feb 7 03:19:37 PST 2009
Clifford J Mugnier [cjmce at lsu.edu] kirjoitti:
> Multiple zones of a single Grid system are often found in overlap areas.  Such is the rule rather than the exception for the U.S. Geological Survey maps of the United States with respect to the State Plane Coordinate Systems.  With respect to the military services, it is found on ALL 1:50,000 topographic maps intended to be used by NATO forces in areas of potential zone overlap.
> Some WWII - era maps of North Africa had three, sometimes four different Grids overprinted on the same paper map.  That was the usual case with the old British Grids in which the Grid boundaries were cut along ellipsoidal loxodromes ... for Europe, too!
Ok. So one of the zones is used for drawing only and the others have just their grids shown on that projection.
The map is still drawn in a single projection zone. (Luckyly they have corner points inverse projected.)
Regards: Janne.
