[Proj] trying to understand results of reprojecting from epsg 4326 to epsg 31370
Frank Warmerdam
warmerdam at pobox.com
Tue Jul 7 09:55:31 PDT 2009
Moritz Lennert wrote:
> On 07/07/09 16:56, Noel Zinn wrote:
>> Consider changing the signs of the three rotations if you can do that
>> manually, or the rotation sense of the 7-parameter transformation.
> That was it. Thanks also to Clifford for the same hint. Could someone
> explain the logic to me ? Why negate the translation, but not the
> rotation compared to the WGS84->Bel72 transformation ?
> And: should the information linked to EPSG code 31370 be corrected ? How
> should I go about doing this ?
Moritz,
File a PROJ.4 ticket and I'll look into it. I need to establish if the
problem is a systematic one in how I translate the parameter from EPSG,
or if it is an incorrect local override or if there is a problem in the
EPSG database itself. I suspect there are two "towgs84" forumulations
in the EPSG database with different handedness and I'm not properly
differentiating them.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
More information about the Proj
