[Proj] trying to understand results of reprojecting from epsg 4326 to epsg 31370
Moritz Lennert
mlennert at club.worldonline.be
Thu Jul 9 10:13:28 PDT 2009
On 07/07/09 18:55, Frank Warmerdam wrote:
> Moritz Lennert wrote:
>> On 07/07/09 16:56, Noel Zinn wrote:
>>> Consider changing the signs of the three rotations if you can do that
>>> manually, or the rotation sense of the 7-parameter transformation.
>> That was it. Thanks also to Clifford for the same hint. Could someone
>> explain the logic to me ? Why negate the translation, but not the
>> rotation compared to the WGS84->Bel72 transformation ?
>> And: should the information linked to EPSG code 31370 be corrected ? How
>> should I go about doing this ?
> Moritz,
> File a PROJ.4 ticket and I'll look into it.
done
http://trac.osgeo.org/proj/ticket/47
> need to establish if the
> problem is a systematic one in how I translate the parameter from EPSG,
> or if it is an incorrect local override or if there is a problem in the
> EPSG database itself. I suspect there are two "towgs84" forumulations
> in the EPSG database with different handedness and I'm not properly
> differentiating them.
Not really both the bel72 -> wgs84 and bel72 -> etrs89 use the same
handedness.
Moritz
More information about the Proj
