[Proj] Error in make check for version 4.6.1 in test 'testvarious', does not occur in version 4.6.0
Maarten Plieger plieger at knmi.nl
Wed Jul 8 08:25:11 PDT 2009
Hi All,
We are having a problem with compiling proj4 version 4.6.1, when running
'make check' a problem occurs in one of the tests:
./testvarious ../src/cs2cs
Running ./testvarious using ../src/cs2cs:
doing tests into file td_out, please wait
diff td_out with td_out.dist
3,4c3,4
< 111d00'00.000"W 44d00'00.000"N 0.0 111dW 44dN 0.000
< 111d00'00.000"W 39d00'00.000"N 0.0 111dW 39dN 0.000
 > 111d00'00.000"W 44d00'00.000"N 0.0 111d0'3.085"W 43d59'59.756"N 0.000
 > 111d00'00.000"W 39d00'00.000"N 0.0 111d0'2.604"W 38d59'59.912"N 0.000
7,8c7,8
 > 111d00'00.000"W 44d00'00.000"N 0.0 111d0'2.788"W 43d59'59.725"N 0.000
11,14c11,14
< 79d58'00.000"W 37d02'00.000"N 0.0 79d58'W 37d2'N 0.000
< 79d58'00.000"W 36d58'00.000"N 0.0 79d58'W 36d58'N 0.000
 > 79d58'00.000"W 37d02'00.000"N 0.0 79d58'0.005"W 37d1'59.998"N 0.000
 > 79d58'00.000"W 36d58'00.000"N 0.0 79d57'59.128"W 36d58'0.501"N 0.000
 > 79d58'00.000"W 37d02'00.000"N 0.0 79d57'59.126"W 37d2'0.501"N 0.000
PROBLEMS HAVE OCCURED
test file td_out saved
make[2]: *** [check-local] Error 100
make[2]: Leaving directory
`/nfs/libs/nadc/swmaint/RHE5_20090707/packages/proj-4.6.1/nad'
make[1]: *** [check-am] Error 2
make[1]: Leaving directory
make: *** [check-recursive] Error 1
Is there a problem with 4.6.1 or is there a problem with our
configuration? We will stay currently at version 4.6.0 which runs fine.
Thanks in advance,
 Maarten Plieger
Maarten Plieger
KNMI, R&D Information and Observation Technology, De Bilt
(t) +31 30 2206330
