[Proj] map coordinates in different coordinate system
Gerald I. Evenden
geraldi.evenden at gmail.com
Thu Jul 9 18:13:43 PDT 2009
On Thursday 09 July 2009 8:31:29 pm Hamish wrote:
> Gerald wrote:
> > As pointed out before, the [+]south option only applies to
> > [+]proj=utm and causes the addition of 10,000,000 meters
> > to the northing (y) value so that it is positive in the
> > southern hemisphere.
> FWIW (in "Frank's" PROJ.4 at least) aea and stere also consider
> +south, but in those cases it changes the sign of Pi/2.
> Hamish
> (mid-winter)
The above usages are longtime standard proj.4.
I was purely referring to the TM area previousl discussed.
The whole religious complexion of the modern world is due
to the absence from Jerusalem of a lunatic asylum.
-- Havelock Ellis (1859-1939) British psychologist
More information about the Proj
