[Proj] trying to understand results of reprojecting from epsg4326 to epsg 31370
OvV_HN
ovv at hetnet.nl
Wed Jul 8 08:34:18 PDT 2009
----- Original Message -----
To: "PROJ.4 and general Projections Discussions" <proj at lists.maptools.org>
Sent: Tuesday, July 07, 2009 6:36 PM
Subject: Re: [Proj] trying to understand results of reprojecting from
There are two different geodetic conventions to the sense of the rotations
used for 7-parameter transformations. There is the right-handed rule used
by the Americans and the Australians, and the left-handed rule used by the
Europeans.
Reply from Oscar van Vlijmen:
Then again, it really helps to read the fu... (erm... fabulous) manual.
In the pdf article found under
"Transformaties tussen geografische cöordinaten (φ,λ) en vlakke coördinaten
(x,y) voor Lambert 1972 en 2008."
on the page
http://www.ngi.be/NL/NL2-1-7.shtm
everything regarding rotation models, signs, errors wrt the Lambert 1972
projection is clearly explained.
It is possible that there is also a French version of that article
available.
More information about the Proj
