[Proj] trying to understand results of reprojecting from epsg4326 to epsg 31370
Moritz Lennert
mlennert at club.worldonline.be
Thu Jul 9 00:12:54 PDT 2009
On 08/07/09 17:34, OvV_HN wrote:
> ----- Original Message -----
> From: "Clifford J Mugnier" <cjmce at lsu.edu>
> To: "PROJ.4 and general Projections Discussions" <proj at lists.maptools.org>
> Sent: Tuesday, July 07, 2009 6:36 PM
> Subject: Re: [Proj] trying to understand results of reprojecting from
> There are two different geodetic conventions to the sense of the rotations
> used for 7-parameter transformations. There is the right-handed rule used
> by the Americans and the Australians, and the left-handed rule used by the
> Europeans.
> Reply from Oscar van Vlijmen:
> Then again, it really helps to read the fu... (erm... fabulous) manual.
> In the pdf article found under
> "Transformaties tussen geografische cöordinaten (φ,λ) en vlakke coördinaten
> (x,y) voor Lambert 1972 en 2008."
> on the page
> http://www.ngi.be/NL/NL2-1-7.shtm
> everything regarding rotation models, signs, errors wrt the Lambert 1972
> projection is clearly explained.
> It is possible that there is also a French version of that article
> available.
I'm sorry, but I don't see where in this document I can see a hint about
different geodetic conventions concering the sense of rotation, be it in
the Dutch or the French version...
Moritz
More information about the Proj
