[Proj] Locate a point from distance and backwards azimuth?
Karney, Charles
ckarney at Sarnoff.com
Tue Jun 23 07:54:20 PDT 2009
> From: Mikael.Rittri at carmenta.com
> Date: Monday, October 20, 2008 03:36
> Here is a variation of the first/principal/forward geodetic problem:
> Known:
> Position of point C.
> Distance from point C to an unknown point A.
> Azimuth, at A, of the great-circle arc between A and C.
> Where is A?
> Note the difference from the first/principal/forward problem: the
> azimuth is known at the unknown point A, instead of at the known point
> C.
> I am not really sure when this is useful, but I have been asked about
> it twice by different people, so I feel I ought to solve it some day.
> Does this problem has a name, and are there detailed published
> solutions anywhere?
This is, apparently, an old chestnut. It is "IVe cas." on p. 489 of
L. Puissant,
Nouvel essai de trigonométrie sphéroidique
[New essay on spheroidal trigonometry],
Mém. l'Acad. Roy. des Sciences de Paris 10, 457-529 (1831).
http://books.google.com/books?id=KcjOAAAAMAAJ
The table on p. 521 shows the other cases that Puissant treats.
Puissant discusses this in the context of a spheroidal earth.
If you're happy with a spherical solution, then I suggest
L. Euler,
Principes de la trigonométrie sphérique tirés de la méthode des
plus grands et plus petits
[Principles of spherical trigonometry taken from the method of the
maxima and minima],
Mém. de l'Acad. Roy. des Sciences de Berlin 9,
223-257 (1753, publ. 1755).
http://math.dartmouth.edu/~euler/pages/E214.html (figures missing)
His "Prob. X" on p. 254 treats the case you're interested in.
Charles Karney <ckarney at sarnoff.com>
Sarnoff Corporation, Princeton, NJ 08543-5300
Tel: +1 609 734 2312
Fax: +1 609 734 2662
More information about the Proj
