[Proj] Accurate algorithm for geodesic calculations
support.mn at elisanet.fi
Mon Mar 2 00:36:14 PST 2009
Ok,
I am assuming that this calculates the elliptic path (on some reference ellipsoid)
between any 2 points, without elevation? Yes?
Can sombody post same for a direct "laser line" between any two points and
with elevation on both ends. This must be a more common problem when doing
shorter ground measurements.
Actually there might be some use for all those versions...
I know that they correct GPS signals about 30 m at the equator max. due to earth
rotation (Sagnac term). If using a laser, should one do the same adjustment? What
would that measure then be (at the equator)?
Janne.
Charles Karney [ckarney at sarnoff.com] kirjoitti:
> I've implemented an algorithm for geodesic calculations for an ellipsoid
> with the following features:
> * It uses expansions accurate to 8th order in the ellipsoid flattening.
> This gives 12 nm accuracy using doubles and 6 pm accuracy using long
> doubles.
> * The direct calculation uses a reverted series and is therefore
> non-iterative. A mechanism is provided to do a series of direct
> calculations on a single geodesic which is faster by a factor of 2.5.
> * The inverse calculation uses Newton's method to determine the
> azimuth. This typically converges in 3 iterations. I haven't found
> any cases where it fails to converge.
> * I provide a large test set geodesics for the WGS84 ellipsoid which is
> accurate to 0.1 pm and 10^-18 degree. Thus was generated by Maxima
> using 20th order expansions (approximately accurate to 1 part in
> 10^50).
> Further information is available at
> http://charles.karney.info/geographic/geodesic.html
> The code itself (C++ classes and a program for doing geodesic
> calculations) is available at
> This compiles with g++ and Visual Studio 2005.
> Still to do:
> * Reduce the order of the expansions to match precision available with
> doubles.
> * Improve the starting guesses for Newton's method to reduce to number
> of iterations in some cases.
> * More documentation on the method.
> * Provide Maxima code to generate the expansions.
> Charles Karney <ckarney at sarnoff.com>
> Sarnoff Corporation, Princeton, NJ 08543-5300
> URL: http://charles.karney.info
> Tel: +1 609 734 2312
> Fax: +1 609 734 2662
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
More information about the Proj
