[Proj] towgs params and epsg code for Italy regions
massimo di stefano
massimodisasha at yahoo.it
Mon Mar 9 08:14:08 PDT 2009
Hi All,
usually i need to reproject Italian data
from
Gauss Boaga rRome 40
to
Wgs 84
and inverse
when i need a good precision on a local scale extent, i use a set of
control points (IGM95 vertex)
and apply last sqare methods to perform 2 different geometrics
transformation :
1) conforme transformation (4 parameters valid for only planimetry) ->
Tx (longitude - tanslation)
Ty (latitude - translation)
λ (scale factor)
α (rigid rotation)
2) affine transformation (6 parameters valid for only planimetry) ->
λx (longitude scale factor)
λy (latitude scale factor)
α (rigid rotation)
ϒ (angular sliding)
to transform vector files i apply the transformation parameters using
pythn-gdal
but maybe (really i don't know) ...
it is possible to use these params directly in proj
(like we can do with cs2cs or including it inside an epsg code?)
an oher question :-/ ...
when i don't need more acuracy i use the follow +towgs params :
all the Italian region :
towgs84 = −225.000, −65.000, 9.000
Italian peninsular part :
towgs : −104.1, −49.1, −9.9, 0.971, −2.917, 0.714, −11.68
Sardinia :
towgs84 = −168.6, −34.0, 38.6, −0.374, −0.679, −1.379, −9.48
Sicily :
towgs84 = −50.2, −50.4, 84.8, −0.690, −2.012, 0.459, −28.08
i have taken the above params directly from grass gis and i include it
in the epsg file that come with the proj source code.
Using it inside the epsg code 3004 - 3003 the errors is drastically
reduced.
... my question :
instead of setting manually a customized projection,
is it possible to define new epsg code based on the +towgs paprameters
inside the epsg file
and redistribuite it with the proj source code ?
.... a lot of software student and newbie gis users can beneficiate of
it.
i agree i can manually add it to the epsg file, but mybe there is a
reason beacouse these parameters are not already inside it ?
a license problem ?
Thanks to All for any answers,
Massimo Di Stefano
epifanio on irc.freenode.net /join gfoss
Massimo Di Stefano
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20090309/af0cfa1b/attachment.html>
More information about the Proj
