[Proj] Geodesic distances away from the ellipsoid
Gerald I. Evenden geraldi.evenden at gmail.com
Fri Mar 20 10:24:43 PDT 2009
On Friday 20 March 2009 12:56:53 pm Jay Hollingsworth wrote:
> At the risk of asking a dumb question, do any of the geodesic
> algorithms allow calculation of the geodesic distance if the path is
> not on the ellipsoid? Like in an airplane or satellite whose path
> could be assumed to be a constant height above the ellipsoid?
> Or do you have to define an ellipsoid matching the satellite orbit
> and use the normal equations on that ellipsoid? If so, how would you
> define an ellipsoid for a long airplane flight?
> I've poked around and nothing has jumped out at me. I assume
> aero-engineers guys figured this out long ago....
I think the solution is fairly simple: just scale you path by the ratio:
R = approximate radius of the Earth over flights path
h = flight height
geodesic length * (R+h)/R
There is also the 3D geodesic at the NGS site which might apply and give a
better answer.  But I think the above would be good enough for most purposes.
Try both and see what happens.
PS: I did not convert the NGS 3D because it was hard-wired for WGS84 and the
description was confusing enough that I decided against bothering for the
time being.  Also, I could not get a mental image of what was happening when
there was a difference of altitude at the two end points.
> Jay Hollingsworth
> Seabed Portfolio Manager and
> Principal Data Architect
> Schlumberger Information Solutions
> phone: 713 513 8854 fax: 713 513 2093
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
The whole religious complexion of the modern world is due
to the absence from Jerusalem of a lunatic asylum.
-- Havelock Ellis (1859-1939) British psychologist
