[Proj] Geodesic distances away from the ellipsoid
OvV_HN
ovv at hetnet.nl
Fri Mar 20 11:49:55 PDT 2009
----- Original Message -----
From: "Gerald I. Evenden" <geraldi.evenden at gmail.com>
To: <proj at lists.maptools.org>
Sent: Friday, March 20, 2009 6:24 PM
Subject: Re: [Proj] Geodesic distances away from the ellipsoid
> There is also the 3D geodesic at the NGS site which might apply and give a
> better answer. But I think the above would be good enough for most
> purposes.
> Try both and see what happens.
> PS: I did not convert the NGS 3D because it was hard-wired for WGS84 and
> the
> description was confusing enough that I decided against bothering for the
> time being. Also, I could not get a mental image of what was happening
> when
> there was a difference of altitude at the two end points.
The last time I looked at the code the geodesic was calculated for an
altitude of 0 meters above the ellipsoid, all the way. I forgot where the 3D
information was used for, probably the chord distance or the north-east-up
coordinate difference.
Oscar van Vlijmen
More information about the Proj
