[Proj] Cosmetic latitudes, and the diacritics of Josef Krovak and others
strebe at aol.com
strebe at aol.com
Mon Mar 23 10:59:21 PDT 2009
daan wrote (about a central latitude that doesn't affect the shape of the
projection):
> Snyder includes it explicitly in his formulations, referring
> to it as the "latitude of origin" and denoting it as φ₀.
Yes, now that you mention it. I have never noticed it before, but Snyder
uses phi_0 when the parameter does not affect the projection shape, but
otherwise he uses phi_1 (which he often calls the "latitude of the center of
the projection and origin"), or else phi_1 and phi_2 for two standard parallels.
This convention is, in fact, stated in his list of symbols on pages viii - ix,
which I hadn't read carefully enough before.
"Latitude of origin" sounds fine, but I am not too fond of using
many different names for what is called lat_0 in Proj.4. The
EPSG Guidance Note 7.2 has gone too far in this direction, I think.
I like "central latitude" as the only name.
Please note also that "Latitude of origin" is the name in the Well Known Text format specification.
E.g.,
PARAMETER["latitude_of_origin",49],
Regards,
— daan Strebe
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20090323/759ce1a4/attachment.html>
More information about the Proj
