[Proj] transformation in c
Stanislav Bek
bks at centrum.cz
Fri Mar 27 07:08:46 PDT 2009
It does not work yet. In attachment, I send the error
received by running nmake.
Sorry for this beginners' stuff...
Best regards,
Stanislav
______________________________________________________________
> Od: warmerdam at pobox.com
> Komu: "PROJ.4 and general Projections Discussions" <proj at lists.maptools.org>
> Datum: 27.03.2009 12:31
> Předmět: Re: [Proj] transformation in c
>On Thu, Mar 26, 2009 at 2:49 AM, Stanislav Bek <bks at centrum.cz> wrote:
>> Thank you! very helpful.
>> Though... While building all the proj4-files (using MS Visual C++), the following error occurs:
>> Compiling...
>> jniproj.c
>> e:praceinternetprojektzkouska2jniproj.c(47) : fatal error C1083: Cannot open include file: 'proj_config.h': No such file or directory.
>> Would be only a part of the files sufficient for my purpose?
>> (I used proj-4.6.1/src)
>Stanislav,
>You have not provided any detail how you got to this point.
>Are you building using the nmake makefiles provided with
>PROJ.4? Something like:
>nmake /f makefile.vc all
>as described in the README file for building on windows?
>If you choose to create your own MSVC project file,
>then it is up to you to properly define the include path
>and select just the appropriate files for the library. This
>is non-trivial, and should likely only be done if you
>understand the makefile already.
>Best regards,
>I set the clouds in motion - turn up | Frank Warmerdam, warmerdam at pobox.com
>light and sound - activate the windows | http://pobox.com/~warmerdam
>and watch the world go round - Rush | Geospatial Programmer for Rent
>Proj mailing list
>Proj at lists.maptools.org
>http://lists.maptools.org/mailman/listinfo/proj
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20090327/47f2e8f6/attachment.png>
More information about the Proj
