[Proj] ERROR 6: No translation for Double_Stereographic to PROJ.4 format is known.
Hermann Peifer
peifer at gmx.eu
Tue Mar 31 09:22:26 PDT 2009
I see that there is a Trac ticket related to some problems with the
Double_Stereographic projection: http://trac.osgeo.org/gdal/ticket/2487
... but the problem seems to continue. Can this be fixed?
Hermann
Failed to create coordinate transformation between the
following coordinate systems. This may be because they
are not transformable, or because projection services
(PROJ.4 DLL/.so) could not be loaded.
Source:
PROJCS["Stereo_70",
GEOGCS["GCS_Dealul_Piscului_1970",
DATUM["Dealul_Piscului_1970",
SPHEROID["Krasovsky_1940",6378245.0,298.3]],
PRIMEM["Greenwich",0.0],
UNIT["Degree",0.0174532925199433]],
PROJECTION["Double_Stereographic"],
PARAMETER["False_Easting",500000.0],
PARAMETER["False_Northing",500000.0],
PARAMETER["Longitude_Of_Origin",25.0],
PARAMETER["Scale_Factor",0.99975],
PARAMETER["Latitude_Of_Origin",46.0],
UNIT["Meter",1.0]]
Target:
GEOGCS["WGS 84",
DATUM["WGS_1984",
SPHEROID["WGS 84",6378137,298.257223563,
AUTHORITY["EPSG","7030"]],
AUTHORITY["EPSG","6326"]],
PRIMEM["Greenwich",0,
AUTHORITY["EPSG","8901"]],
UNIT["degree",0.01745329251994328,
AUTHORITY["EPSG","9122"]],
AUTHORITY["EPSG","4326"]]
More information about the Proj
