[Proj] msProcessProjection(): Projection library error. no system list, errno: 13
Adrian Popa
adrian_gh.popa at romtelecom.ro
Tue Oct 13 03:52:09 PDT 2009
Hello everyone!
I'm trying to troubleshoot a proj error, and I need your help! I have
started this thread also on the mapserver mailing list, but I didn't
find a solution yet:
http://n2.nabble.com/msProcessProjection-Projection-library-error-no-system-list-errno-13-td3807641.html
I'm running mapserver, and I'm trying to configure it to act as a WMS
server. My data is in wgs84 (epsg:4326) and I want to project it to
mercator projection (epsg:900913).
I have configured the mapfile and the projections according to the
Mapserver documentation and they work as long as the projection sections
are defined like:
PROJECTION
#spherical mercator/google
"+proj=merc +a=6378137 +b=6378137 +lat_ts=0.0 +lon_0=0.0 +x_0=0.0
+y_0=0 +k=1.0 +units=m +nadgrids=@null +no_defs"
END
and
PROJECTION
#WGS84
"+proj=longlat +ellps=WGS84 +datum=WGS84 +no_defs"
END
If I ask for EPSG projections (through WMS), I get the error in the subject.
Here is my WMS url:
http://terra/cgi-bin/mapserv?map=/var/www/html/map/rtc_base.map&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&LAYERS=GranitaJudete&STYLES=&SRS=EPSG:900913
I have tried to debug the problem by using shp2img, and it seems that
mapserver tries to open /usr/share/proj/null as a file. I created a
symlink between /usr/share/proj/epsg and /usr/share/proj/null, and now
shp2img reads the file, but I get the same error while trying to call
the WMS server.
My question is: how can I try to troubleshoot this issue - to see if
there's a problem with proj?
I'd like to mention that I have added <900913> +proj=merc +a=6378137
+b=6378137 +lat_ts=0.0 +lon_0=0.0 +x_0=0.0 +y_0=0 +k=1.0 +units=m
+nadgrids=@null <mailto:+nadgrids=@null> +no_defs to my epsg file and my
proj version is:
[adrianp at terra mapserver]$ rpm -qa | grep proj
proj-devel-4.5.0-1.fc5
proj-4.5.0-1.fc5
Regards,
Adrian
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20091013/82fc0f62/attachment.html>
More information about the Proj
