[Proj] Getting X Y in a .map OZI calibrated map
Jorge Ferrando
jferrando at cc.upv.es
Mon Oct 12 10:45:16 PDT 2009
I have some .map OZI calibrated maps. From those .map, I can get some
calibration points (x y in the jpeg picture + lon lat in WGS84).
MMPXY,1,142,142
MMPXY,2,5217,142
MMPXY,3,5217,3422
MMPXY,4,142,3422
MMPLL,1, -0.269639, 39.626293
MMPLL,2, -0.186306, 39.626293
MMPLL,3, -0.186306, 39.584626
MMPLL,4, -0.269639, 39.584626
With that I build a coordinates file
-0.269639 39.626293 (142,142)
-0.186306 39.626293 (5217,142)
-0.186306 39.584626 (5217,3422)
-0.269639 39.584626 (142,3422)
>From the .map file I can also know that the map projection is UTM
Map Projection,(UTM) Universal Transverse
Mercator,PolyCal,No,AutoCalOnly,No,BSBUseWPX,Yes
With proj4 I get the projection of those points in UTM
$ proj +proj=utm +ellps=WGS84 coord
734345.05 4389843.39 (142,142)
741498.53 4390064.29 (5217,142)
741643.45 4385438.93 (5217,3422)
734485.67 4385218.08 (142,3422)
El objetivo es dadas unas coordenadas cualquieras dentro del mapa (p.e.
-0.269058 39.599662), obtener el punto x y en el mismo.
The goal is knowing a pair of coordinates in the map (for instance -0.269058
39.599662), get the x y pixel in the map.
-0.269058 39.599662
734484.83 4386888.69
How can I calcultate the X Y pixel for those coordinates having all this
data? Am I in the right way
Thank you very much
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20091012/7f4b87e9/attachment.html>
More information about the Proj
