[Proj] cs2cs's +towgs84 usage
Jean-Claude REPETTO jrepetto at free.fr
Fri Apr 23 05:39:15 PDT 2010
Le 23/04/2010 14:24, Ilumas a écrit :
> Anyway, I believe that the behaviour of a certain towgs84 string is easy
> to test with cs2cs itself: just do the transformation to one direction
> (e.g. from WGS84) and convert the resulting coordinates back to the
> original datum using exactly the same parameter string. If the resulting
> coordinates equal to the original ones, no negation is needed. Right?
> ilumas
I think you are wrong. To check the parameters, you need to know the
coordinates of at least one point in both datums, and compare them with
the results of cs2cs.
Jean-Claude
