[Proj] cs2cs's +towgs84 usage
Ilumas muginaa at gmail.com
Sat Apr 24 01:02:11 PDT 2010
Well, I agree that for assessing the accuracy of the re-projection results
one needs a reference, but that should not be necessary for understanding
the behavior of the cs2cs or the towgs84 string. Therefore I still argue
that the test I suggested below is a valid way to test whether the parameter
values need to be negated or not. Anyone?
ilumas
On Fri, Apr 23, 2010 at 3:39 PM, Jean-Claude REPETTO <jrepetto at free.fr>wrote:
> Le 23/04/2010 14:24, Ilumas a écrit :
> > Anyway, I believe that the behaviour of a certain towgs84 string is easy
> > to test with cs2cs itself: just do the transformation to one direction
> > (e.g. from WGS84) and convert the resulting coordinates back to the
> > original datum using exactly the same parameter string. If the resulting
> > coordinates equal to the original ones, no negation is needed. Right?
> > ilumas
> Hi,nding the behavious of the cs2cs
> I think you are wrong. To check the parameters, you need to know the
> coordinates of at least one point in both datums, and compare them with
> the results of cs2cs.
> Jean-Claude
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20100424/642b483c/attachment.html>
