[Proj] Welcome to the "Proj" mailing list
jamesmikedupont at googlemail.com jamesmikedupont at googlemail.com
Sat Jan 2 15:15:35 PST 2010
http://www.openstreetmap.org/user/h4ck3rm1k3/diary/9117
Please help :
I am doing the coord transform like that :
echo 358376.5 7753537 | cs2cs -v +proj=utm +south +ellps=intl
+zone=24K +units=m -f "%.7f"a
# ---- From Coordinate System ----
#Universal Transverse Mercator (UTM)
# Cyl, Sph
# zone= south
# +proj=utm +south +ellps=intl +zone=24K +units=m
# ---- To Coordinate System ----
#Lat/long (Geodetic alias)
# +proj=latlong +ellps=intl
-40.3564136a -20.3105983a 0.0000000a
and it works, but now I want to do this in c++
see the code in MText.cpp
http://github.com/h4ck3rm1k3/TwoNickels
void convertPoint(double x, double y, double & rx, double & ry)
  projPJ pj_merc, pj_latlong;
if (!(pj_merc = pj_init_plus("+proj=utm +south +ellps=intl +zone=24K
+units=m")) )
exit(1);
if (!(pj_latlong = pj_init_plus("+proj=latlong +ellps=intl")) )
exit(1);
point_offset, double *x, double *y, double *z );
double ax[1], ay[1], az[1];
ax[0] = x * DEG_TO_RAD;
ay[0] = y * DEG_TO_RAD;
az[0] = 0;
/** end of "caution" section. */
pj_transform(pj_merc, pj_latlong, 1, 1, ax, ay, az);
//printf("%.4f\t%.4f -> %.4f\t%.4f\n", *lat, *lon, y[0], x[0]);
rx = ay[0];
ry = ax[0];
Program produces ERROR::
node id='-905' version='1' ' lat='-26.92552447' ' lon='0.01349053807'
k='easting' v=358360.6875
k='northing' v=7753529
On Sun, Jan 3, 2010 at 12:14 AM,  <proj-request at lists.maptools.org> wrote:
> Welcome to the Proj at lists.maptools.org mailing list!
> To post to this list, send your email to:
>  proj at lists.maptools.org
> General information about the mailing list is at:
>  http://lists.maptools.org/mailman/listinfo/proj
> If you ever want to unsubscribe or change your options (eg, switch to
> or from digest mode, change your password, etc.), visit your
> subscription page at:
>  http://lists.maptools.org/mailman/options/proj/jamesmikedupont%40googlemail.com
> You can also make such adjustments via email by sending a message to:
>  Proj-request at lists.maptools.org
> with the word `help' in the subject or body (don't include the
> quotes), and you will get back a message with instructions.
> You must know your password to change your options (including changing
> the password, itself) or to unsubscribe.  It is:
>  etepsiwe
> Normally, Mailman will remind you of your lists.maptools.org mailing
> list passwords once every month, although you can disable this if you
> prefer.  This reminder will also include instructions on how to
> unsubscribe or change your account options.  There is also a button on
> your options page that will email your current password to you.
