[Proj] Welcome to the "Proj" mailing list
Frank Warmerdam
warmerdam at pobox.com
Sun Jan 3 14:41:03 PST 2010
jamesmikedupont at googlemail.com wrote:
> void convertPoint(double x, double y, double & rx, double & ry)
> projPJ pj_merc, pj_latlong;
> if (!(pj_merc = pj_init_plus("+proj=utm +south +ellps=intl +zone=24K
> +units=m")) )
> exit(1);
> if (!(pj_latlong = pj_init_plus("+proj=latlong +ellps=intl")) )
> exit(1);
> point_offset, double *x, double *y, double *z );
> double ax[1], ay[1], az[1];
> ax[0] = x * DEG_TO_RAD;
> ay[0] = y * DEG_TO_RAD;
> az[0] = 0;
James,
The above five lines (point_offset on) appear to be corrupted in the email.
I followed your link and searched around a bit for MText.cpp with no luck.
The print statement commented out does not seem to reflect the text you
report so it is hard to know how things were being run.
I would suggest you recompose your question to be easier for folks to
address.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
More information about the Proj
