[Proj] Trouble integrating Proj4 into application
Eric Miller
EMiller at dfg.ca.gov
Mon Jun 14 14:27:06 PDT 2010
James,
If I understand your message, you are having a build error, not a runtime problem. I think you might be missing the library search path for the linker (-L/usr/local/proj4/lib or whatever). It probably is similar to whatever you used for the include search path (-I/usr/local/proj4/include or whatever).
Eric G. Miller
Staff Programmer
CA Dept. of Fish & Game
>>> On 6/14/2010 at 12:03 PM, "James Kilroy" <jt_kilroy at yahoo.com> wrote:
> Hello All,
> My name is James Kilroy and I am a brand new user of Proj4. I have an
> extensive GIS back ground so I have a good grasp of the concepts, and I have
> been coding professionally (C/C++) for over 20 years. I have installed the
> code base for Proj4 on my Linux server (Fedora, very recent build). The
> build went without a hitch, all programs test out fine. My problem is I
> can't get the lib to compile into my project. Keeps giving me lib not found
> errors, though the lib is built, in place, and has proper permissions. Are
> there any specific compiler directives required or ENV variables that are
> needed that I am not aware of?
> Thanks,
> James Kilroy
More information about the Proj
