[Proj] Trouble integrating Proj4 into application
Hamish
hamish_b at yahoo.com
Tue Jun 15 03:36:17 PDT 2010
James wrote:
> I have installed the code base for Proj4 on my
> Linux server (Fedora, very recent build). The build went without a
> hitch, all programs test out fine. My problem is I can't get the lib
> to compile into my project. Keeps giving me lib not found errors,
> though the lib is built, in place, and has proper permissions.
you've encountered a classic:
1. add /usr/local/lib to /etc/ld.so.conf
2. as root run ldconfig.
regards,
Hamish
More information about the Proj
