[Proj] Trouble integrating Proj4 into application
James Kilroy
jt_kilroy at yahoo.com
Tue Jun 15 13:17:00 PDT 2010
Thanks for the help guys, got all of my issues worked out, the lib is working beautifully.
James T. Kilroy
----- Original Message ----
To: PROJ.4 and general Projections Discussions <proj at lists.maptools.org>
Sent: Tue, June 15, 2010 7:32:37 AM
Subject: Re: [Proj] Trouble integrating Proj4 into application
If you don't want to muck around with the system files, there are two
other possible solutions.
(1) Define LD_LIBRARY_PATH, with one of
export LD_LIBRARY_PATH=/usr/local/lib:$LD_LIBRARY_PATH
(depending on whether LD_LIBRARY_PATH is already defined or not). This
tells the program loader where to look for shared libraries with running
an executable.
(2) Alternatively, link with
-Wl,"-rpath=/usr/local/lib" -L/usr/local/lib
The rpath command writes the search path for shared libraries into the
executable.
________________________________________
From: proj-bounces at lists.maptools.org [proj-bounces at lists.maptools.org] On Behalf Of Hamish [hamish_b at yahoo.com]
Sent: Tuesday, June 15, 2010 06:36
James wrote:
> I have installed the code base for Proj4 on my
> Linux server (Fedora, very recent build). The build went without a
> hitch, all programs test out fine. My problem is I can't get the lib
> to compile into my project. Keeps giving me lib not found errors,
> though the lib is built, in place, and has proper permissions.
you've encountered a classic:
1. add /usr/local/lib to /etc/ld.so.conf
2. as root run ldconfig.
regards,
Hamish
Proj mailing list
Proj at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/proj
Proj mailing list
More information about the Proj
