[Proj] PROJ.4 parameters for EPSG:3053
    Jean-Claude REPETTO
    jrepetto at free.fr
    Tue Jun 22 03:09:26 PDT 2010
Hello,
I am looking for the projection parameters of the Hjorsey 1955 / Lambert
1955 projection (Iceland).
The epsg file shipped with PROJ4 contains this warning:
Unable to translate coordinate system EPSG:3053 into PROJ.4  format.
I don't know the reason of this warning, may be it is because the LCC
projection is west oriented ?
Are the following parameters correct for this projection :
+proj=lcc +lat_1=65 +lat_0=65 +lon_0=-18 +k_0=1 +x_0=500000 +y_0=500000
+ellps=intl +towgs84=-73,46,-86,0,0,0,0 +units=m +no_defs
Does anybody know sample maps or GCPs using this projection, to check
the parameters ?
Thanks for your help,
Jean-Claude
More information about the Proj
