[Proj] PROJ.4 parameters for EPSG:3053
Tue Jun 22 07:17:11 PDT 2010
Jean-Claude REPETTO wrote:
> Hello,
> I am looking for the projection parameters of the Hjorsey 1955 / Lambert
> 1955 projection (Iceland).
> The epsg file shipped with PROJ4 contains this warning:
> Unable to translate coordinate system EPSG:3053 into PROJ.4  format.
> I don't know the reason of this warning, may be it is because the LCC
> projection is west oriented ?
> Are the following parameters correct for this projection :
> +proj=lcc +lat_1=65 +lat_0=65 +lon_0=-18 +k_0=1 +x_0=500000 +y_0=500000
> +ellps=intl +towgs84=-73,46,-86,0,0,0,0 +units=m +no_defs
> Does anybody know sample maps or GCPs using this projection, to check
> the parameters ?
Jean-Claude,
The problem is EPSG:3053 uses method 9826 which is LCC west oriented.  I
would appreciate it if you could file a ticket in the PROJ.4 track on this
coordinate system, and I should be able to add support for it in a future
version of PROJ.4 using the new axis orientation support.
Please include any test points you are confident of in the ticket so I
can confirm whatever comes out is right.
Best regards,
