[Proj] Using EPSG codes with cs2cs
R.Vives vivesraf at gmail.com
Tue Oct 5 14:59:05 PDT 2010
Hello,
Is it possible to use EPSG codes with cs2cs? I tried the following command:
"cs2cs +init=epsg:4326 +to +init=epsg:32632"
but it didn't work, i only get this message:
"Using from definition: init=epsg:4326
Rel. 4.7.1, 23 September 2009
<cs2cs>:
projection initialization failure
cause: Unknown error
program abnormally terminated"
Regards
Rafael
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Using-EPSG-codes-with-cs2cs-tp5605047p5605047.html
Sent from the PROJ.4 mailing list archive at Nabble.com.
